usb or uart/usart
Discussion in 'Embedded Systems and Microcontrollers' started by sasek, Jan 3, 2010.
  1. sasek
    Jan 3, 2010
    64
    i have project need used bluetooth usb, now i dnt know what the easy way to interface it with PIC, i have problem to program the usb....:confused:
  2. maxpower097
    Feb 20, 2009
    795
    388
    Not sure I completely understand your question. Some of the newer pics support USB OTG which makes things pretty easy to hook up to a USB host or device. As far as bluetooth you will need a secondary IC to control this. I don't think PIC has any onboard support for BT.
  3. sasek
    Jan 3, 2010
    64
    so i need use max232 to convert usb signal?
    i look at pic18f455 header file seam usb not there
    btw thank maxpower097
