usb milliwatts
Discussion in 'General Electronics Chat' started by aac9876, Apr 15, 2007.
  1. aac9876
    Thread Starter Active Member
    Dec 9, 2006
    124
    about how many milliwatts does a common usb port push,
    like thru a usb wifi adaptor?
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    You can find out a lot of infromation on the USB 2.0 spec at www.usb.org.
    It looks as though 2.5 watts is about the max.
    hgmjr
  3. n9352527
    Oct 14, 2005
    1,198
    100mA at 5V normally with standard descriptor. Up to 500mA max. at 5V available with successful negotiation only. So that's 0.5W and 2.5W respectively like hgmjr posted above.
  4. aac9876
    Dec 9, 2006
    124
    if you ad a 1 watt amp to either one, would it be more powerful or not
    because it is already over 1 watt...??? thanks
