usb grounding
Discussion in 'Computing and Networks' started by nattu428, Jul 7, 2014.
  1. nattu428
    Jun 19, 2014
    which ground is given to usb2.0??? and why???
  2. Ramussons
    May 3, 2013
    561
    92
    Power ground.
    Because the +5 Volt is on 1 pin and its return on the other :D
    The pins are + 5 Volts
    Data -
    Data +
    Power Return / 0 Volts / Power Ground.
    Ramesh
  3. nattu428
    Jun 19, 2014
    i mean to say analog ground or digital ground.....
  4. wmodavis
    Oct 23, 2010
    737
    150
    Power return as Ramussons said. Signal is differential so Gnd not rqd.
