Hi guy's,
I was wondering if anyone can see the problem with my code, I had it set up to receive and transmit using code I found on the net, got the receive part working okay but my transmit wasn't so I cut it down to just the transmit part as you can see below
I'm pretty sure the problem is on the microcontroller side of things rather than the PC but I can't see what's wrong.
Rich (BB code):
PROCESSOR PIC16F876
INCLUDE <P16F876.inc>
#define VERSION "=Serial_Com_A===V0.1=="
__CONFIG _CP_OFF & _DEBUG_OFF & _LVP_OFF & _WRT_ENABLE_ON & _PWRTE_ON & _WDT_OFF & _BODEN_ON & _XT_OSC
; Variable Definition
CBLOCK 0x20 ;Start at H'20'
TIMER1 ;Used in delay routine
TIMER2 ; " " "
DATA_TO_SEND
ENDC
ORG 0 ;Reset vector address
GOTO RESET ;goto RESET routine when boot.
; * Example of a delay routine *
DELAY_ROUTINE MOVLW D'255' ;54 Generate approx 10mS delay at 4Mhz CLK
MOVWF TIMER2
DEL_LOOP1 MOVLW D'255' ;60
MOVWF TIMER1
DEL_LOOP2 DECFSZ TIMER1,F
GOTO DEL_LOOP2
DECFSZ TIMER2,F
GOTO DEL_LOOP1
RETLW 0
; SEND CHARACTER IN W VIA RS232 AND WAIT UNTIL FINISHED SENDING
send movwf TXREG ; send data in W
TransWt bsf STATUS,RP0 ; RAM PAGE 1
WtHere btfss TXSTA,TRMT ; (1) transmission is complete if hi
goto WtHere
bcf STATUS,RP0 ; RAM PAGE 0
return
; ** RESET : main boot routine **
RESET BSF STATUS,RP0 ;Switch to register bank 1
;Disable pull-ups
;INT on rising edge
;TMR0 to CLKOUT
;TMR0 Incr low2high trans.
;Prescaler assign to Timer0
;Prescaler rate is 1:256
MOVLW B'11010111' ;Set PIC options (See datasheet).
MOVWF OPTION_REG ;Write the OPTION register.
CLRF INTCON ;Disable interrupts
MOVLW B'10000001'
MOVWF TRISC ;bit 0 and 7 are inputs all others are outputs
MOVLW B'00000000'
MOVWF TRISB ;all RB ports are outputs
MOVLW B'00000000' ;all RA are outputs
MOVWF TRISA
movlw d'25' ;
movwf SPBRG ; set Baud rate to9600 @ 4Mhz(crystal)
movlw B'00100110' ;
movwf TXSTA ; enable 8bit data transmission
BCF STATUS,RP0 ;Switch Back to reg. Bank 0
movlw B'10010000' ;
movwf RCSTA ; enable 8bit data reception
main movlw B'01100001'
movwf DATA_TO_SEND
movf DATA_TO_SEND,W
call send
call DELAY_ROUTINE
call DELAY_ROUTINE
goto main
;****End of the program****
END
