Urgent!!
Newflickerer
Joined May 26, 2014
So, I cant find anywhere on the web how to RESET a logic circuit, any kind of circuit at all. I want to understand, HOW does a relay or capacito RESTARTS a circuit after a positive response from a logic gate? So I have an electronic door and once i put the code, it OPENS, then it closes (RESET) back again, it CANT BE OPEN FOREVER, just right after I put the correct combination. how does it does that with a relay or capacitor or anything else?
any kind of help, even small explanations will be very appreciated, thanks
Wendy
Joined Mar 24, 2008
23,429
Welcome to AAC.
I am assuming you are new to digital logic. Look up the truth table for a set reset flip flop, the most basic reset there is.
When you put a title into a thread, try to make it as descriptive as possible. If you give me the title you would like I can change it on your thread, assuming another moderator doesn't beat me to it.
