Urgent
Discussion in 'General Electronics Chat' started by atotoarere, Nov 27, 2006.
  1. atotoarere
    Nov 27, 2006
    8
    p/z, can anybody help me out of these questions ?
    (1) WHY DO AMERICA CONSUMER SUPPLY RATE WAS 110 VOLT 60HZ.
    (2) OPERATION OF A KEROSENE BLOW LAMP.
    (3) FUNCTIONS OF A KEROSENE BLOW LAMP.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Wikipedia is your friend.
    Dave
  4. Chris Wright
    Jul 26, 2006
    62
    Actually, Most houses in the U.S. are supplied with 240 volts, but by a three wire system. The step-down transformer is a 240v with a center tap that provides two 120v hot lines and a neutral. Electric stoves, water heaters, baseboard heat, electric dryers, etc. all run on 240v. (I have a table saw and an air compressor on 240v at home). It is the wall outlets and the lighting that are 120v. Now It seems that a 120v bulb is cheaper and sturdier than a 240 bulb, and since the overwhelming use of electricity in the beginning was lighting it kind of makes sense. Here is an interesting Wiki article on the different worldwide systems:
    http://en.wikipedia.org/wiki/Split_phase
