list p=10F206 ; list directive to define processor
#include <p10F206.inc> ; processor specific variable definitions
__CONFIG _MCLRE_OFF & _CP_OFF & _WDT_OFF
; '__CONFIG' directive is used to embed configuration word within .asm file.
; The lables following the directive are located in the respective .inc file.
; See respective data sheet for additional information on configuration word.
;***** VARIABLE DEFINITIONS
TEMP_VAR UDATA
delay1 equ 0x08
delay2 equ 0x09 ;assign memory locations for variables
currnote equ 0x0A
duration equ 0x0B
tone equ 0x0C
notedata equ 0x0D
durationindex equ 0x0E
toneindex equ 0x0F
testend equ 0x10
testrest equ 0x11
RESET_VECTOR CODE 0x1FF ; processor reset vector
; Internal RC calibration value is placed at location 0x1FF by Microchip
; as a movlw k, where the k is a literal value.
MAIN CODE 0x000
movwf OSCCAL ;update register with factory cal value
bcf OSCCAL,FOSC4 ;oscillator output to GP2 disabled
movlw b'00010111' ;wake on pin change and weak pullups enabled,
OPTION ;timer transition on internal clock, assign prescaler to timer, prescaler value 1:256
bcf CMCON0,CMPON ;comparator off
movlw b'00001000'
tris GPIO ;set GP3 input, GP0-GP2 outputs
movlw b'00000000'
movwf GPIO ;clear output buffer
detectbutton
btfsc GPIO,3 ;button pushed? (GP3 low?)
sleep ;no button go to sleep
movlw 0x00 ;button pushed-reset note pointer to 0
movwf currnote
nextnote
call getnote ;get a note to play
call decode ;decode duration and tone data
goto nextnote
getnote
movf currnote,w ;current note pointer to W
call songtable
movwf notedata
movwf testend
incf testend
decfsz testend ;is notedata=0 (testend=1)(end of song marker)?
goto continue ;song not over
goto detectbutton ;song is over-check the button
continue
incf currnote ;increment note counter
retlw 0x00
decode
movf notedata,w ;notedata to register w :dddttttt
movwf tone ;notedata to tone
movwf duration ;notedata to duration
movlw b'00011111'
andwf tone,f ;clear bits 7:5 of tone: 000ttttt
movlw b'11100000'
andwf duration,f ;clear bits 4:0 of duration: ddd00000
swapf duration,f ;move bits 7:4 to 3:0 and 3:0 to 7:4: 0000ddd0
rrf duration,f ;rotate right from carry: c0000ddd
bcf duration,7 ;clear bit from carry (just in case): 00000ddd
movf duration,w
call durationtable
movwf durationindex
movf tone,w
call tonetable
movwf toneindex
play
clrf TMR0 ;reset timer
incf toneindex,w ;is toneindex=0? (rest)
movwf testrest ;same as is testrest=1
decfsz testrest
goto toneloop ;not a rest
movlw d'200' ;a rest
movwf toneindex ;load a value for inner delay loop
goto restloop
restloop
bcf GPIO,2 ;GP2 goes low
call delay
btfss TMR0,7 ;check timer MSB
goto restloop ;no timer yet
bcf TMR0,7 ;timer detected clear TMR0 MSB
decfsz durationindex,F ;decrement durationindex
goto restloop ;not done yet
retlw 0x00 ;done
toneloop ;start tone generation
bsf GPIO,2 ;GP2 goes high
call delay
goto halfcycle ;no timer yet
bcf TMR0,7 ;timer detected, clear TMR0 MSB
goto halfcycle ;not done yet
retlw 0x00 ;done
halfcycle
call delay
goto toneloop ;no timer yet
goto toneloop ;not done yet
retlw 0x00 ;done
delay
movlw d'5' ;load delay1 counter
movwf delay1
delay_loop1
movf toneindex,w ;load delay2 counter
movwf delay2
decfsz delay1,F ;decrement delay1 until zero (outer loop of 1 deep nested loop)
goto delay_loop2 ;goto nested inner loop
retlw 0x00 ;return from the call
delay_loop2
decfsz delay2,F ;decrement delay2 until zero (inner loop of 1 deep nested loop)
goto delay_loop2 ;not done decrementing. Stay in inner loop.
goto delay_loop1 ;done decrementing. Return to outer loop.
durationtable
addwf PCL,f
retlw 0x1 ;000=1/64 note
retlw 0x2 ;001=1/32 note
retlw 0x4 ;010=1/16 note
retlw 0x8 ;011=1/8 note
retlw 0x10 ;100=1/4 note
retlw 0x20 ;101=1/2 note
retlw 0x40 ;110=whole note
retlw 0x80 ;111=2 whole notes
tonetable
addwf PCL,f
retlw d'0' ;00000=rest-no tone
retlw d'222' ;00001=F#3/G3b
retlw d'210' ;00010=G3
retlw d'198' ;00011=G3#/A4b
retlw d'186' ;00100=A4 <---------A220
retlw d'176' ;00101=A4#/B4b
retlw d'166' ;00110=B4
retlw d'156' ;00111=C4
retlw d'147' ;01000=C4#/D4b
retlw d'139' ;01001=D4
retlw d'131' ;01010=D4#/E4b
retlw d'123' ;01011=E4
retlw d'116' ;01100=F4
retlw d'110' ;01101=F4#/G4b
retlw d'103' ;01110=G4
retlw d'97' ;01111=G4#/A5b
retlw d'92' ;10000=A5 <----------A440
retlw d'86' ;10001=A5#/B5b
retlw d'81' ;10010=B5
retlw d'77' ;10011=C5
retlw d'72' ;10100=C5#/D5b
retlw d'68' ;10101=D5
retlw d'64' ;10110=D5#/E5b
retlw d'60' ;10111=E5
retlw d'57' ;11000=F5
retlw d'53' ;11001=F5#/G5b
retlw d'50' ;11010=G5
retlw d'47' ;11011=G5#/A6b
retlw d'44' ;11100=A6 <---------A880
retlw d'42' ;11101=A6#/B6b
retlw d'39' ;11110=B6
retlw d'37' ;11111=C6
songtable
addwf PCL,f ;add offset to program counter
retlw b'10001110' ;G4/4
retlw b'10010011' ;C5/4
retlw b'01100000' ;rest/8
retlw b'01100110' ;B4/8
retlw b'10000100' ;A4/4
retlw b'10000110' ;B4/4
retlw b'10010101' ;D5/4
retlw b'10110011' ;C5/2
retlw b'10000000' ;rest/4
retlw b'10010111' ;E5/4
retlw b'01110011' ;C5/8
retlw b'10010110' ;D#5/4
retlw b'10110101' ;D5/2
retlw b'10110111' ;E5/2
retlw b'10011000' ;F5/4
retlw b'11000000' ;rest/1
retlw b'00000000' ;END OF SONG (1/64 REST)
END ; directive 'end of program'
#include "stdio.h"
main () {
printf("Hello World\n");
return 0
Probably the grand prize winner in the clueless category! The clincher is the line "...due in fifteen minutes."HELP!!!
I have to write a program to do something and it doesn't work.
What's wrong?
Please post correct code.
I need it NOW!
Assignment is due in fifteen minutes.
dude... rest assured, help is on its way... just sit tight and breath in a bag 'till the nine-nine-oners get there....Anyone?
Why won't anyone help me?
I NEED this NOW!
Yep. I figured it was rant here or rant there -- because there WAS going to be a rant!We already have 2 or 3 of these today. Probably what stimulated WBahn to have a rant.
(and I'm not pretending I don't have an occasional rant.)
Yeah... I didn't know what else to call them... we don't have a 911 system down here where I live...The nine-nine-oners?
Let me guess, they'll be here in sixteen minutes.
They have an app for thatHELP!!!
What's wrong?
I need it NOW!
ROFLI think I have a remedy.
There's a book with the words "Don't Panic" in nice soothing letters on the cover...
Duh! Hello! "Nine-Eleven"! You press '9' followed by '11'!What number do I dial for 911??
HELP!!!
What's wrong?
I need it NOW!
11 what?Duh! Hello! "Nine-Eleven"! You press '9' followed by '11'!
Incorrect. Please dial 411 and they will tell you what numbers you need to push to dial 411.Duh! Hello! "Nine-Eleven"! You press '9' followed by '11'!
Well, Duh back at you. My phone does not have an "11" button, so there!!Duh! Hello! "Nine-Eleven"! You press '9' followed by '11'!
