Urgent, Timer Delay
Discussion in 'The Projects Forum' started by G8NPH, Feb 24, 2008.
  1. G8NPH
    Feb 24, 2008
    I need a timer delay circuit so when there is a pulse the circuit will wait 10-15 seconds then a output pulse will occure
    any circuit suggestions and layouts and pictures would be usefull
    G8NPH
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    What's your application?
    What is the input pulse, positive or negative? What amplitude?
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    You can get that sort of delay with a 555, but I would probably use a dual voltage comparator (LM393) with the first comparator as a buffer and the second with an RC delay input. If you need the schematic, ping back. John
