URGENT REPLY
Discussion in 'The Projects Forum' started by aliashar86, Apr 25, 2009.
  1. aliashar86
    Thread Starter Active Member
    Nov 23, 2006
    71
    I AM WORKING ON PRIVATE BRANCH EXCHANGE AND AM BLOCKED WITH MY WORK DUE TO UN AVAILABILITY OF 2 IC'S IN MY AREA.
    PLZ HELP ME OUT BY TELLING ANY ALTERNATIVE FOR THESE:
    IC'S ARE
    1) LCA110 (HOOK SWITCH)
    2) L9711 (RING DETECTOR)
    DETAILS CAN BE SEEN ON THIS LINK
    http://www.kmitl.ac.th/~kswichit/PABx/PABx.htm
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Since we don't know where you are, finding a supply of them far away from you probably won't help you very much.
  3. aliashar86
    Nov 23, 2006
    71
    i live in pakistan. i need to know any alternative for these IC's
  4. eblc1388
    Nov 28, 2008
    1,542
    102
    For the hook switch it is an opto TRIAC. You can use MOC3021 for it.
    The ring detector is a simple opto-isolator, 4N26 or any similar opto-isolator will work well.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    This may not help you much, but Mouser shows some cross-reference matches for the LCA110, which are solid-state relays:
    http://www.mouser.com/Search/Refine.aspx?Keyword=LCA110
    G3VM-351B - Omron Electronics
    LH1546AT - Vishay
    Datasheets are available from the link above.
    This schematic:
    http://www.kmitl.ac.th/~kswichit/PABx/Download/PABx.pdf
    indicates that the L9711 is some kind of optocoupler.
    A Motorola MITL117 appears to have a compatible pinout.
    So do Fairchild's 4N2x, 4N3x and H11Ax series optocouplers; they are all shown in the 4N25 datasheet.
    Not knowing what voltages to expect in your circuit, I'll leave it to you to figure out which may be suitable.
  6. aliashar86
    Nov 23, 2006
    71
    i need the schemetic of "wireless switch" and i too want to confirm that when i connect it with my PBX through RJ11 so what additional things i have to do to make it work with it wirelessly.
