URGENT: PM Generator in Reverse
Discussion in 'General Electronics Chat' started by Management, Oct 23, 2009.
  1. Management
    Thread Starter Active Member
    Sep 18, 2007
    306
    If you have a permanent magnet generator being driven by a turbine and the generator outputs some power level, how would the configuration of a generator change if it is suppose to drive a turbine's compressor stage with the same power?
    I think the meaning is how would one change the generator to a motor that supplies the same output power.
    I just don't understand applying electrical power to the stator would make a PM rotor move.
    Any details would be appreciated.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    This certainly doesn't seem like an "urgent" question to me.
  3. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    A permanent magnet generator for dc ( generators are usually dc ) has a commutator and brushes to make dc. It is thus a dc motor as well. I think the same equations between voltage and rpm apply in either mode.
  4. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Maybe the OP forgot to put it in the homework forum.
