URGENT, Please Help
Discussion in 'Homework Help' started by junyan, May 20, 2008.
  1. junyan
    May 13, 2008
    7
    Please help me with this problem. I am not sure of my answer, I keep thinking that the answer should be in ohm's not mho's:
    A Delta connected three-phase motor has a resistance of 60 ohms and an inductive reactance of 15 ohms per phase. If the motor is replaced by an equivalent Y connected load, the phase characteristic of the equivalent load should be? (in rectangular form)
    My answer was 0.05 + j0.2 mho
    Thank you for your assistance with this perplexing problem.
    J
  2. junyan
    May 13, 2008
    7
    I thought about my answer and re-worked the problem. The correct answer was 20 + j5 ohms. I want to thank everyone who took the time out of their busy day to consider this problem. :D
