Urgent!! (i want to create a full wave rectifier}
Discussion in 'Homework Help' started by Halim.Akiki, Dec 29, 2014.
  1. Halim.Akiki
    Dec 29, 2014
    44
    Hello
    I have a small project and i want to create a full wave rectifier. I drew the following circuit
    But i am having a negative result [​IMG][​IMG]
    Can anyone help me?
    The sine wave is :
    DC = 0 V
    AC = 16 V
    VOFF = 0 V
    VAMPL = 16 V
    FREQ = 60 Hz
  2. djsfantasi
    Apr 11, 2010
    2,900
    876
    Can't see your images. If you are having problems, take a look at my blog entry here.
    Halim.Akiki likes this.
  3. WBahn
    Mar 31, 2012
    18,085
    4,917
    Post your (reasonably sized, like under 100KB) images as attachments to your post (use the Upload a File link at the bottom).
  4. Halim.Akiki
    Dec 29, 2014
    44
  5. Halim.Akiki
    Dec 29, 2014
    44
    Are they clear now?
  6. MrChips
    Oct 2, 2009
    12,624
    3,451
    Of course you will get negative voltages. Turn your rectifiers around.
  7. Halim.Akiki
    Dec 29, 2014
    44
    Are they clear now?
  8. Halim.Akiki
    Dec 29, 2014
    44
    Thank you very much. I turned the rectifiers and the output turned out right. But when i added a resistor on the output i had the following result.
  9. MrChips
    Oct 2, 2009
    12,624
    3,451
    Then increase the value of C1 to 1000μF.
    BTW, use a thread title better than Urgent!!
  10. Halim.Akiki
    Dec 29, 2014
    44
    Thank you! I will use better titles.
  11. WBahn
    Mar 31, 2012
    18,085
    4,917
    What size resistor did you use? How can we give good feedback if you don't give us the information?
    Since your output appears to be drooping from 14V down to 1V and that is being pulled from a 0.83uF cap, that means that you are pulling about 11uC of charge from it. Since that is being pulled out in 1/120th of a second, that's an average current of about 1.3mA. Since the average voltage is about 6.5V, I'm going to guess that you are using something like a 5kΩ resistor. Is that close?
    If you follow how I did that, then see if you can work backwards to find a good capacitor value to use to keep the droop (also known as ripple) below a desired value.
  12. Halim.Akiki
    Dec 29, 2014
    44
    Man you're a genius!
  13. WBahn
    Mar 31, 2012
    18,085
    4,917
    Wouldn't go anywhere near that far, that's for sure. But thanks anyway.
    What size resistor were you using?
    Did that help you size your capacitor better?
    What was the final result?
  14. Halim.Akiki
    Dec 29, 2014
    44
    I was u sing a 1K resistor. increasing the capacitor's size to 10mF made the result perfect.
  15. WBahn
    Mar 31, 2012
    18,085
    4,917
    Yeah, in increase by a factor of 10,000 probably reduced your ripple voltage for that size load down to a millivolt or two. It will give you a pretty high inrush current, though.
  16. MrChips
    Oct 2, 2009
    12,624
    3,451
    Please note that 1mF is 1000μF.
  17. WBahn
    Mar 31, 2012
    18,085
    4,917
    Yes. So an increase from 0.83uF to 10mF is an increase by a factor of over 12,000.
