urgent help with I2C communication between two PIC16f877a, one master one slave
Discussion in 'Embedded Systems and Microcontrollers' started by sairyuva, May 6, 2010.
  1. sairyuva
    Mar 9, 2010
    11
    Can any one help me with I2C?
    What should I do at salve side of PIC16f877a
    MPLAB v8.33
    HITECH C compiler 9.7
    Ω°Ω°Ω°Ω°
  2. kingdano
    Member
    Apr 14, 2010
    377
    19
    *sigh*
    no one can help you with such minimal information.
    please post more detail or delete your post
  3. Art
    Distinguished Member
    Sep 10, 2007
    797
    61
    Why not use ordinary serial comms?
    I2C was implemented to talk to third party chips.
    I'm not sure you'd find existing routines for communications on the slave side.
  4. retched
    Dec 5, 2009
    5,201
    313
    I had a burn and the doctor put salve on it.
    But I wouldnt but salve on a PIC16f877a, unless it had dry skin. ;)
    As for you other problem, What are you using as the MASTER, and why are you using I2C?
  5. sairyuva
    Mar 9, 2010
    11
    i m just starting
    Please see this code and state my mistake
    Code ( (Unknown Language)):
    1.
    2. /*master.c*/
    3. #include<htc.h>
    4.
    5.
    6. __CONFIG(HS & WDTDIS & PWRTEN & LVPDIS & BORDIS);
    7.
    8. unsigned char _data, i=0x00;
    9.
    10. void Init_I2C()
    11. {
    12.     TRISC3=0;    //SCL
    13.     TRISC4=0;    //SDA
    14.     SSPCON=0x38;
    15.     SSPCON2=0x00;
    16.     SMP=1;
    17.     SSPEN=1;
    18.     CKE=0;
    19.     SSPIF=0;
    20.     BCLIF=0;    //bus collision flag
    21.     SSPADD=0x63;
    22.     SEN=1;
    23.     TRISB=0x00;
    24.     PORTB=0x00;
    25.     TRISD7=0;
    26.     RD7=0;
    27. }
    28.
    29.
    30.
    31.
    32.
    33.
    34.
    35.
    36.
    37. void main()
    38. {
    39.     Init_I2C();
    40.
    41.     while(1)
    42.     {
    43.
    44.         SEN=1;
    45.         ACKSTAT=1;
    46.         i=0;
    47.
    48.
    49.         RCEN=1;
    50.         ACKEN=1;
    51.
    52.         while(SSPIF==0);
    53.         SSPIF=0;
    54.
    55.         SSPBUF=i;
    56.         i++;
    57.
    58.         while(SSPIF==0);
    59.         SSPIF=0;
    60.         SSPBUF=i;
    61.         i++;
    62.
    63.         while(SSPIF==0);
    64.         SSPIF=0;
    65.         PEN=1;
    66.         while(SSPIF==0);
    67.         SSPIF=0;
    68.         delay_Nms(100);
    69.     }
    70. }
    71.
    1.
    2. /*slave.c*/
    3.
    4.
    5. #include<htc.h>
    6.
    7.
    8.
    9.
    10. __CONFIG(HS & WDTDIS & PWRTEN & LVPDIS & BORDIS);
    11.
    12. unsigned char _data;
    13.
    14.
    15.
    16.
    17.
    18.
    19.
    20. void Init_I2C()
    21. {
    22.     TRISC3=1;    //SCL
    23.     TRISC4=1;    //SDA
    24.     SSPCON=0x3E;    //slave mode
    25.     SSPCON2=0x00;
    26.     SMP=1;
    27.     ei();
    28.
    29.     CKE=0;
    30.     CKP=1;
    31.     SSPEN=1;
    32.     SSPIF=0;
    33.     SSPADD=0x69;
    34.     BCLIF=0;
    35.     TRISB=0x00;
    36.     PORTB=0x00;
    37.     TRISD7=0;
    38.     RD7=0;
    39.     SEN=1;
    40.     SSPOV=0;
    41. }
    42.
    43.
    44.
    45.
    46.
    47.
    48. void main()
    49. {
    50.     Init_I2C();
    51.     while(1)
    52.     {
    53.         PORTB=_data;
    54.
    55.     }
    56. }
    57.
    58. void interrupt ISR(void)
    59. {
    60.     if(SSPIF)
    61.     {
    62.         if(RW==1)
    63.         {
    64.
    65.             RD7=1;
    66.             _data=SSPBUF;
    67.             CKP=1;
    68.         }
    69.         SSPIF=0;
    70.
    71.     }
    72. }
    73.
  6. retched
    Dec 5, 2009
    5,201
    313
    What are you talking to with the I2C bus? A PIC on one side, but what is on the other?
  7. sairyuva
    Mar 9, 2010
    11
    its PIC16f877a both
  8. retched
    Dec 5, 2009
    5,201
    313
    Ok, so you want 2 PIC 16f877a to talk to each other.
    Is this an assignment or can you choose to use a different communications protocol?
  9. sairyuva
    Mar 9, 2010
    11
    Assisgnment
  10. retched
    Dec 5, 2009
    5,201
    313
    ok. What are you using as a clock for the master? I see nothing in you code.
  11. sairyuva
    Mar 9, 2010
    11
    20Mhz XTAL
  12. retched
    Dec 5, 2009
    5,201
    313
    Can you post a schematic of your master and slave setup?
  13. sairyuva
    Mar 9, 2010
    11
    I used Proteus Vsm to test it
