urgent help required
Discussion in 'The Projects Forum' started by gowhar, Nov 25, 2013.
  1. gowhar
    Nov 24, 2013
    i have 2 nos of transformers extracted from an old ups "Luminous 750Va double battery" the transformer has this marking on it. TX-201-1000-02. i just want to know that can i use them to build an inverter in the range between 200 to 500 watt power inverter for my home. second is that i am confused with the connections on primary and secondary side. it has 7 wires coming out from pri winding and 3 wires coming from secondary side. how can i identify which wire is which and thier voltages.
    thanking you in antcipation.
    goher, India
  2. sirch2
    Jan 21, 2013
    1,008
    351
    Why is this urgent?
  3. Electric Al
    Member
    Nov 6, 2013
    59
    8
    Do you know what the best thing to do with that junk is ?
    Tie a rope to it and use it to anchor your boat .
    Unless you have a death wish .
    It's obvious that you do not have the knowledge to tackle a project like you think you have .
    :eek:
