Urgent Help Plz - what is gain bandwidth product
Discussion in 'General Electronics Chat' started by cranny, Feb 28, 2005.
  1. cranny
    Feb 28, 2005
    Hi all,
    Im new here :huh:
    Ive got a problem, lab report due tomorrow, my fault for leaving it so late but have been snowed under with other work.
    just about finished it, but having to return to a bit i missed out.
    here is the background - built an Intruder alaram system - detects sounds through mic and if over a certain threshold then signals the alarm, was designed to connect to a motion (ultrasound) detector through an oscillator.
    here are the modules:
    receiver >> invert op amp >> rectifier >> comparator >> oscillator >> led/buzzer
    one of the points i need to answer is:
    "explain what is meant by the gain bandwidth product of a closed loop amplifier and its significance for this project".
    i calculated the GBP to be 750Hz but no idea why - got a table of results, is it something to do with half of some quantity?
    I never realised the importance of a decent lab book until now - i am only in first year and am still learning.
    please help and save my day :(
    iain
    uk
  2. cranny
    Feb 28, 2005
    pritty please
  3. shreyas_bhat
    Jul 26, 2004
    47
    Hi Cranny
    am not a geek myself. But I could make an attempt at answering ur question. Gain Bandwidth product indicates the gain of a device at a particular frequency.
    It is usually associated with amplifiers, which require you to generate certain amount of gain. By saying the GBP for an amp is 1 MHz, all it means is that the amplifier can give a maximum gain of unity at 1 MHz.
    Hope this brings u out of troubled waters
    Shreyas
  4. shreyas_bhat
    Jul 26, 2004
    47
    Well, if you have a GBP of 750 Hz, it means that ur amplifier can produce a max. gain of 1 at 750 Hz.
    I presume ur sound detector should operate at certain frequencies (presumably the human audible range - 20 to 20000 Hz). From what I understand, ur ckt. will not amplify signals over 750 Hz (although they fall in the audible range). Therefore, this is of great concern. An alternative could be the use of a High Gain Bandwidth op-amp.
