Urgent Help Please - Newbe out of control!
Discussion in 'The Projects Forum' started by usdiggs, Dec 4, 2006.
  1. usdiggs
    Dec 4, 2006
    8
    Hi, I need some help to design what sounds like a simple project. All it needs to do is count up or down (displaying on 7 segment displays) when a button is pressed. I have been trying to use Ic's SN74192 as the counter and SN74247 as the display driver. It only need to be up to 99.
    As well as this I also want to have another display that counts down (MM:SS) from 2 minutes. Once it has counted down to zero, then it resets to blank state or just stays at zero.
    Any help here would be much appreciated.
    Thanks, Dazed & Confused
    :confused: :eek:
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    How about posting your circuit design so far. This will give the members a starting point in assisting you with your design.
    hgmjr
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    That's 99 hex, not decimal, right? Converting hex to BCD takes a lot more than two chips...
  4. Gadget
    Distinguished Member
    Jan 10, 2006
    613
  5. usdiggs
    Dec 4, 2006
    8
    Thanks Hgmjr, I have started by trying to get one 7 segemnt display working as I under stand the cascading to add more on. I have attached a jpeg of my little mess.
  6. nomurphy
    Aug 8, 2005
    567
    12
    The LOAD signal has no source, it is not driven, neither is it pulled up or down (this also affects the NAND gate inputs).
    Also, the CLEAR and preset lines A-D need to be terminated appropriately.
    ALWAYS terminate any unused inputs to the appropriate state.
  7. usdiggs
    Dec 4, 2006
    8
    Ok, Thanks. Now what does that mean? Sorry I am very new to this. Are you able to edit the jpg? or sketch it si I can see what you mean. Thanks
  8. nomurphy
    Aug 8, 2005
    567
    12
    See attached:
  9. usdiggs
    Dec 4, 2006
    8
    Thanks sooo much. You have been a huge help & a lot of progress has been made.
    Thanks Again
    Aaron:D
