Urgent help for led load
Discussion in 'General Electronics Chat' started by shyckh, Sep 11, 2014.
  1. shyckh
    Jul 28, 2014
    24
    HHi i want to blink 2 set of leds each containg 16 leds each. These leds must blink out of phase with respect to each other. I have used monostable osscilator (555 timer) and give the output to 1 set of led.also i have used an inverter at the output of Timer. The output of inverter is given to other set of led. The intencity of 2nd set is very low. Need help how to increase the power. What values of resistance should i used to get enough power to light up these leds. Any other suggestion will also be appreciated. See the circuit diagram of inverter also. Thanks
  2. wayneh
    Sep 9, 2010
    12,396
    3,246
    Your attachments are identical. Do you have other transistors to choose from, or are you locked into one particular model?
    That's an inefficient way to accomplish the inversion. Let's come up with something better.
  3. shyckh
    Jul 28, 2014
    24
    Its not compulsry to use this transistor. I also have 2n2222 transiator
  4. shyckh
    Jul 28, 2014
    24
    Its not compulsory to use this transistor...
  5. shyckh
    Jul 28, 2014
    24
    Tell me how can i make it more efficient??
  6. wayneh
    Sep 9, 2010
    12,396
    3,246
    Switch the current in the second bank of LEDs exactly as you do the first, using the transistor as the control over the return to ground. But connect the base of the second transistor to the collector of the first. This will turn the 2nd transistor on when the 1st is off, and vice versa. You'll want the appropriate resistor on the base of the 2nd transistor, to limit the base current to 10% of the current used by the LED bank.
  7. shyckh
    Jul 28, 2014
    24
    If you can draw the circuit diagram for me for better understanding. It should be a great help
  8. shyckh
    Jul 28, 2014
    24
    Oh ! You are saying to connect transistor in cascaded way,????
  9. Jony130
    Feb 17, 2009
    3,993
    1,116
    Or you can use this circuit
    And are you sure that you don't need astable gen ?
  10. shyckh
    Jul 28, 2014
    24
    Yes iam sure i dont need astable gen... But this circuit will solve power issue but one set of led will flicker so rapidly so that my software dose not detect its flickering. Any way to slow down the switching speed??? Leds attached to 555 tiner has been detected by the software but other set has not been detected
