URGENT!! -- Automatic Light Sensor project
Discussion in 'General Electronics Chat' started by loveek9, May 9, 2009.
  1. loveek9
    May 9, 2009
    Hi
    I am building a light sensor project which i have designed. I am measuring ambient light using LDR and passing it to my computer using Parallel port. then i am defining some preset voltages in the CPU, which i will compare with the LDR output. The difference of pre-defined voltage and LDR output is what i want to give to the LED Lamp through serial port. But i am not getting the right way to do it.
    Can anyone give me the idea to of how to connect the serial port to the LED lamp???
    I am doing C programming in linux for this project.
    Help as soon as possible will be appreciated!!!
    Thanks,
    Loveek9
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    A schematic of your LDR circuit would be very useful.
    A more complete explanation of
    would also be useful.
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Is it the code you are having trouble with, or the interface?
