UPS Schematic and explanation
Discussion in 'Electronics Resources' started by tigerfish0102, Jan 16, 2010.
  1. tigerfish0102
    Oct 17, 2009
    9
    Hi Guys,
    I'am working as an electrician on board a vessel, i have a problem because two of our UPS for the backup for the control of our main computer and the alarm systen on the engine was not working it does not ON. This problem happen the same to the two UPS GE EP Series. Is there anybody can help me resolve this problem.
    Tigerfish
  2. Duane P Wetick
    Apr 23, 2009
    408
    19
    You will need to provide a better explanation of the problem and a schematic or at least a block diagram of the system. Some diagnostics about what you have discovered so far will help.
    Regards, DPW [ Everyone's knowledge is in-complate...Albert Einstein]
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Here is GE's product page for the EP series UPS:
    http://www.gelighting.com/apo/products/industrial/power_quality/16.htm
    I suggest that you first test the batteries in the UPS to make sure that they are charged to specifications. If they are OK, contact GE technical support, and give them as much information as you can about your situation.
    Having shipboard computers go down is a very bad thing in this day and age.
