UPS not charging on electricity but charge on Generator
Discussion in 'General Electronics Chat' started by walediscovery, Nov 23, 2015.
  1. walediscovery
    Nov 23, 2015
    Good day everyone,
    Please my office 30KVA UPS will not charge on main supply (electricity). It only charge while on generator (plant).
    The batteries are not up to a year.
    Please what do you think is the issue.
  2. kubeek
    Sep 20, 2005
    4,687
    805
    It could be that your wiring is not good enough to sustain the charging current.
    walediscovery likes this.
  3. walediscovery
    Nov 23, 2015
    But the batteries get charged while on company generators. The issue is when you receive power via the power utility company.
  4. Dodgydave
    Jun 22, 2012
    5,140
    767
    Have you measured the mains supply voltage from your office, and compared it with your generator?
    MrSoftware and walediscovery like this.
  5. alfacliff
    Dec 13, 2013
    2,449
    428
    get a real electrician to check the wireing, it is probably wired up that way.
  6. mcgyvr
    Oct 15, 2009
    4,787
    973
    Need wiring diagram showing how generator and mains are attached to UPS..
    Need to know UPS specifications
    Need to know voltage measurements for mains and generator output
    How do you know its not charging?
    As alfacliff stated an electrician should be able to look at it and find out whats wrong easily.
  7. MrSoftware
    Oct 29, 2013
    544
    132
    Is this a problem that suddenly began when the system was working properly in the past? Did anything change just prior to this problem occurring?
    Check your utility line voltage. We had a problem with the line outside our building causing the voltage to sag, and our UPS's were running in boost mode (drawing more current to boost the voltage). Occasionally the voltage would drop low enough that they would trip to battery power, but they would run for extended time in this boost mode. I believe the batteries were not charging when running in this state. It's worth checking if yours is similar. Check the line voltage, and also check the UPS logs is possible, the UPS will likely log the events.
  8. walediscovery
    Nov 23, 2015
    Thanks all. Yes, the issue started this month. It has been working fine prior to this time.
    I will do as advised and revert
