ups center tape transformer
Discussion in 'General Electronics Chat' started by green90, Apr 3, 2016.
  1. green90
    Sep 3, 2015
    23
    why ups center tape transformer is (7.6v-0v-7.6) while i has 12v battery ???
  2. GopherT
    Nov 23, 2012
    6,300
    4,020
    That should be "center tap" transformer.
    Next. 7.6 for each side is 15.2V total AC (as RMS voltage).
    Once the 15.2 v is rectified and smoothed with decoupling capacitors, with minimal load, the DC should be equal to the Peak-to-peak (minus rectifier diode drops). Or, RMS voltage x 1.414 or about 21 volts.
    green90 likes this.
  3. green90
    Sep 3, 2015
    23
    thank you ... but in inverters cct always use 12v-0v-12v while in ups (7.6v-0v-7.6) while in both case using 12v battery
  4. tcmtech
    Nov 4, 2013
    2,106
    1,747
    Read up on Pulse Width Modulation and how its used as a voltage regulation method and you will understand why.
    green90 likes this.
