Hi there,
I am trying to upload the bootloader from arduino to a attiny85 chipset. But got the message stk500_getsync() attempt x of 10: not in sync: resp=0x00..
Ofcourse I already did some research on forums, but nothing was solving the error:
- Holding reset before RX/TX Blinks
- Adding 10uF Capacitor between reset and ground
- Adding 120R on reset
Also tried uploading with a USBASP (2.0), but always got a initialization error with the asp, while I am sure the connections are good.
I am using a (real) Mega as programmer (Arduino as ISP) with pins 50-53 and the ArduinoISP program uploaded to the mega.
This is my output:
Is there someone of you who has a solution for me for this really annoying problem....
This is my output:
Code:
System wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/iMacTom/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
######(Maby this is something but couldn't found information about it)#######
Using Port : /dev/cu.usbmodem1431
Using Programmer : stk500v1
Overriding Baud Rate : 19200
avrdude: stk500_recv(): programmer is not responding
AVR Part : ATtiny85
Chip Erase delay : 400000 us
PAGEL : P00
BS2 : P00
RESET disposition : possible i/o
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 12 4 0 no 512 4 0 4000 4500 0xff 0xff
flash 65 12 32 0 yes 8192 64 128 30000 30000 0xff 0xff
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 2 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
