up down counter
Discussion in 'The Projects Forum' started by onlyvinod56, Nov 5, 2008.
  1. onlyvinod56
    Thread Starter Active Member
    Oct 14, 2008
    362
    Hi, i need a decade counter which can count in both up & down modes.
    I searched on the net. But im not satisfied with those. I need an IC with a pin for up/down modes. If the pin is enabled, it has 2 work in one mode(up/down). And if it is disabled, it should work in the other mode.
    For a triggering pulse, that ic should count from 0~9 and in the other mode for the same triggering it should count from 9~0.
    Is there any IC available with these features?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Check out the CMOS chip 4029, I think you'll find it meets your needs.
