In Electronics today we were playing around with some op-amps. Specifically, TL081 op-amps from ST Microelectronics.
We were only using them as comparators. The inverting input was connected to ground and the noninverting input to a potentiometer. The op-amps and potentiometer were powered from a ±15V supply. When the potentiometer was set at 15V, the op-amp had a 14V output as expected. When set to -7V, the op-amp had a -13.5V output. But when set to -15V, the op-amp went back to 14V...
What could explain this odd behaviour? It did not happen when the op-amp was in the reverse configuration with noninverting input tied to ground and inverting to the pot.
I suspect the input ranges were being exceeded causing odd behaviour.
