unused ic pins
30,824
There is no simple cut and dry answer. It depends on the specific application.
Here are some of the criteria you need to consider:
1) Power consumption
2) Mains power supply vs battery operation
3) Voltage
4) Current
5) Frequency of operation
6) Other circuits and load applied
7) Availability of components
8) Cost
9) Complexity of design
10) Other options available such as microcontroller
shortbus
Joined Sep 30, 2009
10,045
Its for a home shop pulse EDM machine. This is going to be the logic to create the equal voltage pulses needed. To not fire a pulse that is under voltage at it's start or to shut a pulse down if it is shorted.
Frequency variable in the 25KHz to 25KHz range, with variable duty cycle. The logic, mosfet drivers, and stepper motor, will be powered from a computer power supply. No load to logic except for switching the mosfet drivers, that are Cmos or TTL level.
Cost, I've got so much in this now, in failed attempts, now it's me or it. :) And I don't give up easy.:)
Micro probably would be an option if I was younger, but I'm not and learning this stuff is hard enough, with out taking on another level. :) Thanks for your help!
