Unstable Monostable success!!
Discussion in 'General Electronics Chat' started by mbohuntr, Sep 11, 2010.
  1. mbohuntr
    Thread Starter Active Member
    Apr 6, 2009
    Finally, The circuit works on the simulater. I still need to put in the supply filtering cap, and limit the current on the transistor. Do any of you see any issues w/ this circuit?
    Current draw is a concern as this will probably run on 8 AA's. I will adjust the cap and resistor timing values after I build a prototype with a 556. Thanks for the help!!! :D
