unstable load resistor
Discussion in 'General Electronics Chat' started by z_mx, Apr 13, 2013.
  1. z_mx
    Apr 7, 2013
    9
    hi everyone
    first of all i want to say thanks for the replies
    my problem is: i have unstable load resistor (range from 1 to 7 Omh) in next circuit:
    https://www.dropbox.com/s/e418jfys8vdny9h/load.jpg
    i need, that drain current will be constant 4A. what kind of feedback i will must put to the gate from Rload?
    thanx
  2. Ron H
    Apr 14, 2005
    7,050
    657
    have you considered that with a 1Ω load, and 4 Amps, the voltage drop across the MOSFET will be 24V, and the power dissipation will be 96 Watts?:eek:
    That transistor is only good for 1.6 Watts maximum.
    What are you really trying to do? Give us the big picture.
  3. z_mx
    Apr 7, 2013
    9
    hi
    transistor can be stb120nf10 . it doesn't mater. i think that i solved this problem:
    https://www.dropbox.com/s/hukpc59h1bfcud5/loadN.png
    what do you think? thanx
  4. kubeek
    Sep 20, 2005
    4,686
    805
    You can´t possibly ask a to-220 package to dissipate 96W reliably.
    Second thing, how do you plan to achieve those 2.5V?
    What you really need is a bigger mosfer and an op-amp based current source to drive it.
    Does the load need to be grounded, or can it be placed anywhere in the circuit?
  5. Ron H
    Apr 14, 2005
    7,050
    657
    As Kubeek said, you would need an operational current source, but heat removal is going to be your big problem.
    As I said, tell us the big picture. Otherwise, I'm outta here.
  6. z_mx
    Apr 7, 2013
    9
    okay
    i need to develop constant current circuit (4A) in temperature range (-45 to 85 C).
    BUT my load can be from 1 to 7 ohm (random). this is a full picture.((
  7. kubeek
    Sep 20, 2005
    4,686
    805
    The supply voltage is arbitrary? How does the load change - is it gradual?
  8. Ron H
    Apr 14, 2005
    7,050
    657
    Why do you need this?
  9. kubeek
    Sep 20, 2005
    4,686
    805
    The extended industrial range seems rather suspicious, what do you need this for?
  10. z_mx
    Apr 7, 2013
    9
    the part of my final project in college.
  11. Ron H
    Apr 14, 2005
    7,050
    657
    Yeah, at 85C, he will need active cooling.
  12. z_mx
    Apr 7, 2013
    9
    supply voltage 28 V
  13. kubeek
    Sep 20, 2005
    4,686
    805
    The 28V supply doesn´t leave much room for voltage drop across the transistor, does it?
  14. z_mx
    Apr 7, 2013
    9
    i mean constant current in temperature range, circuit will work 10 sec. don't think that need active cooling
  15. kubeek
    Sep 20, 2005
    4,686
    805
    You need something along the lines of this. If you can achive the Vset and R2 to be stable along the temp range, the output will be stable too. Note the because of the drop on R2 and M1 you can never achieve full 4A for a 7Ω load.
    z_mx likes this.
  16. Ron H
    Apr 14, 2005
    7,050
    657
    That's funny. I was going to suggest something almost identical.
    Why did you use 44mV as the reference? That will set the current at 4.4A.
    If the application is what I think it is, I'm not sure we should be helping.:eek:
    z_mx likes this.
  17. kubeek
    Sep 20, 2005
    4,686
    805
    The reference is 44mV because I had to tweak it to get the current spot on, probably because of the offset voltage of the opamp.
    It doesn´t ring any bells, so no idea what the application might be?
  18. kubeek
    Sep 20, 2005
    4,686
    805
    Why does it need to work just for 10 seconds? That is even more odd then the industrial temperature range, what is the rest of your college project?
  19. z_mx
    Apr 7, 2013
    9
  20. Ron H
    Apr 14, 2005
    7,050
    657
    That is a nice try. A current mirror is a huge waste of power. To get 4 amps out, you need 8 amps. Kubeek's circuit is much better.
    Your simulation works because M3 and M6 are identical. Try finding two identical power MOSFETs.
    They say a simulator is no better than the models you use. It is also no better than the operator. Simulators can lead to novice down the garden path.
