Unknown resistor value
Discussion in 'Homework Help' started by kwinterowd, Nov 28, 2011.
  1. kwinterowd
    Nov 28, 2011
    Need help finding value of R2
    Voltage source 115, R1 and R2 are in parallel, R1 100Ω, R2 100mA, R3 is in series R3 150Ω. Should be easy but...
  2. Adjuster
    Dec 26, 2010
    2,147
    300
    ...But apart from the fact that we are not likely to supply direct answers for somebody's circuit theory homework, however basic, we are not mind-readers.
    At the very least, post a schematic and explain your attempt to solve this. What is your difficulty with it?
  3. kwinterowd
    Nov 28, 2011
    R1 100Ω
    +115v-- --R3 150Ω neg
    R2 100mA
    How do I calculate the resistance value of R2?
  4. kwinterowd
    Nov 28, 2011
    115vdc R1//R2 + R3.
    R1=100ohm, R2=100mA, R3=150ohm
    I will try type circuit here.
    ,,,,,,,,,,R1 100 ohm
    +115v,,,,,,,,,,,,,,,,,,,,,,neg
    ,,,,,,,,,,R2 100 mA
    I don't know how to get the ohm value for R2. The textbook isn't very clear. Thanks
  5. kwinterowd
    Nov 28, 2011
    Oops I forgot to put in R3
    ,,,,,,,,,,,,,,R1 100 ohm
    +115v,,,,,,,,,,,,,,,,,,,,,,,,,,,,,R3 150 ohm
    ,,,,,,,,,,,,,,R2 100 mA
  6. Georacer
    Nov 25, 2009
    5,151
    1,266
    If you want to use ASCII art to draw your picture, you should use the
    Code ( (Unknown Language)):
    1.  tags, available in the message toolbar, around your text to avoid automatic reformatting of your image.
  7. Adjuster
    Dec 26, 2010
    2,147
    300
    Make a Thevenin equivalent for the two known resistors R1 and R3 and power supply from R2's point of view.
    Solve for the voltage across R2 given the known 100mA current draw.
