I have some LEDs that I have lost the spec's on. Is there a way to determine the spec's of an LED?
-Don
-Don
Yes. They're single LED's. Do I have to put a resistor in the circuit for this test?If they are single LED units and you have a meter, you can apply some voltage through a resistor. Assume a maximum allowable current of 20 ma through the LED, and a forward drop of 1.5 volts to play safe. When the LED is lit, you can measure the actual forward voltage across the LED and adjust the current accordingly. They will last longer if current is only the order of 10 ma.
Good point.Using a resistor and plotting a set of characteristic curves of current and voltage is the de rigueur way to do it; plus you'll have way more useful information than the datasheet.
You need an adjustable power supply, voltmeter, ammeter, a variable (fixed) resistor, and test LED.Good point.
But I'm unclear on the how part.
by Duane Benson
by Jake Hertz
by Duane Benson
by Jake Hertz
