University Project Help
Discussion in 'Homework Help' started by yaya, Mar 27, 2005.
  1. yaya
    Mar 27, 2005
    I need some major help, much would be appreciated if anyone could offer any help. hell i would even supply a reward or something.
    I want to understand how to find some things out about this particular circuit attached.
    I have achieved Vg=3.9Volts
    Idss=.5mA
    ID=1.6mA
    Vgs=2.89Volts
    and Av=voltage gain=-2.68
    The output impedence i am not sure how to do exactly.
    I have calculated these values but PSpice offers a couple different values. Was wondering if anyone got these values or if not how you got them.
    Consider the AC-coupled amplifier shown below. All capacitors are 10µF. The
    MOSFET has the following parameters: Kn’W/L = 1E-3 A/V2, Vt = 1 V
    2. Calculate the DC-bias point (also called Q-point)
    4. Calculate the small-signal gain of the amplifier stage
    5. Calculate the input and output impedance of the amplifier in the midband
    6. Calculate the small-signal gain of the amplifier with capacitor C3 removed.
    Thank you for ANY help!
    circuit attached
    [attachmentid=517]
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    {Post = UG}
    Due to the wide variation of parameters associated with MOSFET devices, the device part number for the MOSFET being used in your circuit will be needed to make an accurate calculation of the DC bias point.
    Can you post the MOSFET part number?
  3. fobishduck
    Apr 5, 2005
    i suggest you also define the desired performance parameter, including up to what frequency this is to operate at... i suppose you are looking at at least 100MHz, since it's microelectronic class...
    given some more information about what you want to do exactly, i'm sure people here will help out.
  4. mozikluv
    Jan 22, 2004
    1,437
    hi
    here's my contribution for the moment. the cap impedance of your input coupling cap should be lower than the input resistance looking into the gate so that your input cap will act as a short circuit to your sinusoidal signal. :)
  5. mozikluv
    Jan 22, 2004
    1,437
    hi
    here's some useful formulas to help you out ;)
