universal time constant formula
Discussion in 'Homework Help' started by ra1ph, Jan 8, 2010.
  1. ra1ph
    Thread Starter Active Member
    Jan 5, 2010
    31
    Hi i need your help , new to this forum.
    I'm a first year electronics student with semester 1 examination tomorrow.
    I'm trying to understand the universal time constant formula for capacitors. I understand the formula when given: time = >0 my problem is when time = Zero.
    I have read and understand the example given on this site
    Volume I - DC » RC AND L/R TIME CONSTANTS »
    Could someone help me or point me to an example where t = 0?
    Thanking You
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Look at it this way - voltage can only change as the time changes.
  3. Boo
    Member
    Oct 27, 2009
    40
    the expression for charging or discharging always e^-t/RC. Where Rc is the time constant. If 0 time has passed we get e^0 which is simply 1, in other words, nothing has changed.
  4. ra1ph
    Jan 5, 2010
    31
    Ok thanks, My problem was with the (final-start) voltage or current part of the formula. I get it now- nothing has changed!
  5. Boo
    Member
    Oct 27, 2009
    40
    Remember that voltage does not change instantaneously in a capacitor!
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    And current doesn't change instantaneously in an inductor. Same principal, similar math.
  7. ra1ph
    Jan 5, 2010
    31
    Thanks!
    so the following formula is valid for when t = 0
    change=(final-Start)(1-1/e^(t/RC))
    because change = 0 always when t = 0
    It does not matter what the final and start voltages are. I expected to get what the actual voltage or current were are time = 0 when using the formula mentioned.
    So what formula should I use to get the actual values when t = 0 or is just a understanding that you need?
  8. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If the problem starts at T = 0, then the initial states are as given.
  9. hitmen
    Sep 21, 2008
    159
    Just remember the magic formula
    X(t) = x(∞) + x(0)e^-T/tau
    This is what I remembered if I remembered it correctly:D
