Unitronic PLC
Discussion in 'Embedded Systems and Microcontrollers' started by mik3, Jul 7, 2009.
  1. mik3
    Thread Starter Senior Member
    Feb 4, 2008
    4,846
    63
    Hi guys,
    Does anyone know a software capable of programming Unitronic PLCs with function blocks instead of ladder logic?
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    What you using at the minute, U90?
    Dave
  3. mik3
    Feb 4, 2008
    4,846
    63
    I am using Crouzet PLCs now but I want to switch to Unitronic due to their higher capabilities. I am planning to use Vision 280.
  4. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    Ah right, I thought you mention you were using them already. When you mentioned ladder-logic I thought of U90. For the Vision 280 have a look at VisiLogic: http://www.unitronics.com/Content.aspx?Page=Downloads&CatId=4
    I wouldn't like to hazard a guess at how suitable it is for your requirements so have a look at it - it's a free download.
    Dave
  5. mik3
    Feb 4, 2008
    4,846
    63
    I have already downloaded it. You can only use ladder programming, so I have to familiarize myself with it instead of using function blocks.
  6. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    So it's like U90 for the M9x controllers. Seems like a trend for Unitronic IDEs.
    Sorry I cannot suggest anything beyond that.
    Dave
  7. mik3
    Feb 4, 2008
    4,846
    63
    Thanks Dave for the response.
    Which PLC brands do you think are good?
  8. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    Many of guys I work with use and recommend Siemens PLCs (the SIMATIC series), however they are quite expensive and perhaps overkill for many applications. I don't really work with PLCs so my recommendations are both second-handed and limited even if I am moderately familar with the family of Unitronic PLCs.
    Dave
  9. n9352527
    Oct 14, 2005
    1,198
    I concur with Dave. SIMATIC series are nice PLCs. Other brands that I encountered widely used in plants are Mitsubishi MELSEC FX, Allen Bradley and Omron. They can all be programmed using function blocks.
  10. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    Allen Bradley are also recommended for a wide range of programmable controllers.
    Dave
  11. mik3
    Feb 4, 2008
    4,846
    63
    Thanks for the response guys.
  12. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    No problem, mik3.
    As a suggestion, have you considered contacting Unitronics to see if they make a functional-block add-on for Visilogic? I would have thought if they did they would have made it publicly available from their website, but on the off-chance they have something specific they don't distribute openly it might be an idea to flash you question past them.
    Dave
  13. mik3
    Feb 4, 2008
    4,846
    63
    I may ask them but it is ok for me to use ladder as I have got the main idea of it. I prefer function blocks because it is more familiar and friendly to me.
  14. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    Agreed. I would be inclined to exhaust all avenues at Unitronics first, but I guess if it isn't a necessity then that's not too bad. Good luck.
    Dave
