Unit Step Response to Plant Dynamics?
Discussion in 'Homework Help' started by woodmark75, Dec 15, 2014.
  1. woodmark75
    Dec 11, 2014
    36
    I have plotted a unit step response to G(s) which is a transfer function representing an remotely operated vehicle (ROV).
    The issue is that I'm trying to interpret the result. I would have expected the line to drop, showing the ROV dropping due to gravity etc. It doesn't, it climbs?
    G(s)= -0.125(s+0.452)/(s+1.25)(s^2+0.234s+0.0163)
    Unit Step Response : https://app.box.com/s/sxpd9boxnqm3qhokptrl
    Could anyone explain why the plot rises the way it does?
  2. Kermit2
    Feb 5, 2010
    3,849
    964
    your mathmatical expression does indeed return negative values.
    could the problem be in the graphing applications interpretation of the expression. (are you sure it is entered the way it should be for that application)
  3. woodmark75
    Dec 11, 2014
    36
    I'm using Simulink. I used a step input block, entered G(s) as a transfer function block & then put the output to scope?
  4. Kermit2
    Feb 5, 2010
    3,849
    964
    not familar with simulink...whatever it is doing, it is not performing the calculations correctly. try simplifying your function just to see the output is correct then add more elements until you get the problem portion isolated
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    This is the unit step response I obtained....
    No issues as far as I can see. Kermit has probably indicated your likely source of error.
  6. woodmark75
    Dec 11, 2014
    36
