Unit keeps blowing fuses
Discussion in 'Homework Help' started by CR9, Jan 1, 2010.
  1. CR9
    Jan 1, 2010
    8
    In an electrical circuit, if a unit keeps blowing fuses what is usually wrong?(give atleast 3 reasons.)
  2. Duane P Wetick
    Apr 23, 2009
    408
    19
    1. Short circuit (to ground).
    2. Overloaded circuit.
    3. Wrong fuse type or size.
    Regards, DPW [ Everyone's knowledge is in-complete... Albert Einstein]
  3. CR9
    Jan 1, 2010
    8
    is this right answer to the question...
    ---If the unit(or device) keeps blowing fuses, it means that unit has shorted or malfunctioned, or unit is drawing more current than the fuse will allow.---:confused:
  4. whatsthatsmell
    Oct 9, 2009
    102
    The fuse blows because the unit is drawing more current than the fuse allows. That is the given.
    The answer requires that you state the reasons the unit could be drawing more current, as listed in a previous post.
  5. CR9
    Jan 1, 2010
    8
    thanks... DPW and whatsthatsmell
