Unipolar stepper motor
Discussion in 'General Electronics Chat' started by nerdegutta, Nov 15, 2014.
  1. nerdegutta
    Thread Starter Moderator
    Dec 15, 2009
    2,565
    805
    Is this a unipolar stepper motor? I couldn't find any datasheets online. It's from an old Star NX 1000 printer.
    The wires has these colors: Blue, Brown, White, Red and Yellow.
    If it is unipolar, and I don't connect the common wire, can I then use it as a bipolar?
  2. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,507
    You should be able to if the windings match, that seems a little coarse for steps?
    Max.
  3. nerdegutta
    Dec 15, 2009
    2,565
    805
    Coarse, you mean big steps, since it's 7,5 degrees for each step?
  4. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,507
    The 'normal' full step is 1.8°/step or 200 steps/rev.
    Max.
  5. nerdegutta
    Dec 15, 2009
    2,565
    805
    I'm planning of using this motor on a "proof of concept" or a test run application. Eventually I want 0.9 deg step motor.
    Thanks!
  6. RichardO
    May 4, 2013
    1,336
    429
    Since your stepper motor only has 4 wires, it is a bipolar stepper. Aa unipolar stepper has at least 5 wires: 4 phases and a common. Some unipolar steppers have 2 commons instead of 1 for a total of 6 wires.
    I have seen some stepper motors that bring out leads from the ends of all 4 of the windings -- 8 wires. These do not seem too common. That is a good thing because figuring out the wiring without a data sheet would be tricky.
    You can use a unipolar stepper as a bipolar stepper by leaving the common(s) unconnected but the torque ratings will be slightly less than an a bipolar-only stepper drawing the same amount of power. I am not sure but I think the maximum step rate of a unipolar is also poorer than an equivalent bipolar stepper.
  7. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,507
    He shows 5 wires?
    Max.
  8. RichardO
    May 4, 2013
    1,336
    429
    Oops. "Blue, Brown, White, Red and Yellow." 1,2,3,4,5. 1,2,3,4,5. 1,2,3,4,5....
  9. RichardO
    May 4, 2013
    1,336
    429
    I realized after posting the previous reply that I had an oversight.
    A 5-lead stepper may not give even spaced steps if the bipolar drive voltage is not symmetrical. For example, the steps could be 6 degrees and 9 degrees on your 7.5 degree per step motor. The larger steps may decrease torque and reduce the maximum step rate.
  10. nerdegutta
    Dec 15, 2009
    2,565
    805
    The project is put on the shelf for a while. Some other projects is stealing my time.
    Thanks for the relies!
