uninstall ask.com & other ads
Discussion in 'Computing and Networks' started by aamirali, Sep 18, 2014.
  1. aamirali
    Feb 2, 2012
    415
    In browser, I get install these freaking adware/ask.com & other.
    Even I remove them completely from browser or any other they keep on showing again.
    How to remove them permanently.
    1. Will malwarebyte be able to remove them or not
  2. sirch2
    Jan 21, 2013
    1,008
    351
    Google it, there is some good advice out there and next time you install something read very carefully what is on the installation dialogs, uncheck the options for anything except the thing you intend to install.
  3. tom_s
    Member
    Jun 27, 2014
    287
    342
    add/remove programs - ask.com will be there if its installed.
    IE aslo has a feature of totally resetting the browser to default (original) settings.
  4. JDT
    Feb 12, 2009
    658
    85
    Also, if you download something, check very carefully where its coming from. For example: if you want flash player, the URL should have "adobe.com" right at the start.
  5. ISB123
    May 21, 2014
    1,240
    531
    Use Malwarebytes to remove adware otherwise its just going to come back.
  6. studiot
    Nov 9, 2007
    5,005
    515
    I'm sorry to tell you that Malwarebytes may not remove Ask successfully.
    Successful removal depends upon the depth of infection.
    It may simply be that you have not changed your homepage away from Ask (MB does not do this) and the browser goes there and reinfects as soon as you open it.
    Change this offline before using the browser online.
    Sometimes Ask is protected by another program. 'SearchProtect' is one such. Some are hidden.
    Join up to either
    http://www.majorgeeks.com/
    or
    http://www.bleepingcomputer.com/
    and let them help you.
  7. Robert McKay
    Jan 26, 2016
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I recommend the Revo Uninstaller. I kept getting a 1316 Error because it could not locate the original uninstaller in C:\Windows\Installer\...
