UNI-T 81B Scopemeter Problem
Farlander
Joined Oct 14, 2008
158
Hey all -- I blew the capacitance meter on my new scopemeter by trying to measure a hot circuit -- 12V 1A to be precise.
Now the meter reads .243 nF all the time, except for jumps when removing contacts from a cap.
Is this something I can fix or will I have to eat it?
studiot
Joined Nov 9, 2007
4,998
I have one of these, but I'm afraid I haven't been brave enough to look inside yet.
If there you have any questions about measurements on a working one ask and I will try to obtain them for you.
If the rest of the funtions are working you haven't blown the input fuse.
As a warning to others I did notice the sequence of available functions on the rotary switch is
Off
Volts
Ohms
Hertz
microamps
milliamps
amps
capacitance
Off
Having to pass Ohms to get from volts/off to other ranges is a worry. So far I have always disconnected the lead when doing this, which is a nuisance when switching back and fore between HZ and volts.
