Underwater connection - what do you think about these?
Discussion in 'The Projects Forum' started by RyanKH, Dec 26, 2010.
  1. RyanKH
    Dec 26, 2010
    8
    I am working on a project that involves an underwater connection. I've found some products to make the connection, and I'm curious what you think.
    I am sending 12 volts through each pin (one pin at a time). I can't seal or shirnk-wrap the connection because I need the ability to connect and disconnect it.
    What do you think?
    http://www.birns.com/rubk.html
    and/or
    http://www.kinsun.com/product_detail.php?s=139
    Thanks!
    -Ryan
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    Will it be connected/disconnected above water, then used underwater, or are you looking for something for connection/disconnection underwater?
    The Birns are the choice for the first case and sometimes the second. You see those on Jet-Skis, etc.
    What current levels are you working with?
  3. retched
    Dec 5, 2009
    5,201
    313
    The second are reliable, and possibly overkill.
    I would go with the birns RMK 2 conductor version if I was choosing between the two.
  4. RyanKH
    Dec 26, 2010
    8
    Thanks! They would be connected dry/above water, and then put in the water.
    Where do you purchase Birns products? Can my local electrical supply shop order them?
    -Ryan
  5. thatoneguy
    Feb 19, 2009
    6,357
    718
    Contact Page. DigiKey and others I checked do not carry them, they appear to be direct order.
  6. marshallf3
    Jul 26, 2010
    2,358
    201
    I think they're all going to be too expensive to consider. 12V only barely travels through water, try looking at some of the automotive connector choices which aren't cheap either but perhaps a better choice. I think GM calls theirs a Weatherpack connector: http://www.electerm.com/packardweather.html
    Normally sold as kits to auto techs but you can buy the specific ones you want on eBay from what I hear.
    Just about anything automotive is likely to be fine.
  7. thatoneguy
    Feb 19, 2009
    6,357
    718
    Automotive connectors will work if you are dealing with freshwater only. That is, no salts or other ionizing materials added to increase conductance or oxidation (rust) rate of fresh water.
    How often will this be disconnected and connected? If the "cycle count" is low, then automotive type connectors would be a low cost solution. If the connectors are to endure hundreds of cycles, or will be used in saltwater environments, your original picks would be a better choice.
