Understanding Window Comparators
Discussion in 'Homework Help' started by SkiBum326, Jul 15, 2014.
  1. SkiBum326
    May 16, 2014
    33
    Hi Everyone,
    I have a question about window comparators, which are discussed on page 862 of Electronic Principles.
    I attached an image of the window comparator in question. According to the book, when vin is between 3 and 4 V, the output transistor of each comparator is cut off, so the output is pulled up to +5v? I can't imagine why this would be the case. Wouldn't each comparator just go into saturation?
    Thanks in advance for any help,
    Austin
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    Let as assume that Vin = 3.5V. So for the lower comparator we have:
    Vp = 3.5V and Vn = 3V and since (Vp - Vn) > 0 the LM339 output transistor is cut off.
    Now for the upper comparator we have:
    Vp = 4V and Vn = 3.5V.
    And again (Vp - Vn) > 0. And that means when the Vp > Vn, the output will go towards the Vcc line due to the pull up resistor because the output transistor of each comparator is cut off.
    http://forum.allaboutcircuits.com/showthread.php?p=736584#post736584
    SkiBum326 likes this.
  3. SkiBum326
    May 16, 2014
    33
    Jony130,
    Thanks..that makes so much more sense now.
    Austin
