understanding Wait state in MCU
Discussion in 'General Electronics Chat' started by aamirali, Jul 22, 2013.
  1. aamirali
    Feb 2, 2012
    415
    I read that since CPU is fast & flash is slower so when CPU send a request to read data memory from a particular address, flash can send wait cycles & after then it sends ready s/g then after CPU reads data .
    Let 8051 has 2 WS
    So normally like ADD instruction in 8051 is suppose 2MC. Means 24 oscillator cycle. Does that these 24 cycles has 2 WS cucles with it.
    So it is time CPU takes to execute only not read the instruction.
    So a program like takes cycles
    ADD A,R1 /* 2MC(24 cycles) + 2WS cycles */
    SUB A,B /* 2MC(24 cycles) + 2WS cycles */
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    An 8051 has no facility for inserting wait states. You cannot put the processor into an idle state for a slow device.
  3. IC-Man
    Jan 3, 2012
    26
    Waitstates are used on external memory of processors. If all memory(FLASH/SRAM/DRAM) is on-chip it does not need wait states or it is inserted automatically. The execution time given will show this. If an external memory interface is availbe the processor(e.g. to access external DRAM memory) usually waits for a ready signal. If it is not there it will insert another wait cycle. Please check if your 8051 has an external memory interface. If not you can only address external memory through the IO and emulation the handshake in software.
  4. LDC3
    Apr 27, 2013
    920
    160
    The actual number of cycles depends on the instructions. For instructions that involve only internal registers, no wait states need to be inserted.
    SUB A,B /* 2MC (24 cycles) */
    For fetching data from RAM (ROM, etc), wait states are needed.
    ADD A, R1 /* 2MC (24 cycles) + 2WS (24 more cycles) */
