understanding the use of LM3914
david1234
Joined Nov 27, 2013
104
Hello
just want to see I understand ;
I want to monitor a battery of 12V
I have check with power supply and this is the result I get
Vin<9.9v- No led is on
9.9v<Vin<10.6v - the red led is on (LED1,2,3)
10.6v<Vin<11.2v yellow led is on (LED4,5)
Vin>11.2 Green LED is on (LED 6,7,8,9,10)
what do I need to change in the circuit in order to lower Voltage that will light the first LED so in 9.5V the red will go on also?
bertus
Joined Apr 5, 2008
22,277
You can change the lower limit by changing the resistor on pin 4 in your schematic.
A lowering the value will lower the voltage of the lower led.
Have a look at the internal schematic how the comparators are hooked up:
Bertus
david1234
Joined Nov 27, 2013
104
O.k.
can you show me the formula to calculate the right value?
I mean - I understand that now I have ~50K between pin 6 and GND (10 inside of the LM3914 and 40 with my resistor)
but how do I calculate?
Thanks ,
bertus
Joined Apr 5, 2008
22,277
You have a voltage divider of 11:1 on the input.
The reference voltage is 1.25 Volt, the upper led will be 11 X 1.25 = 13.75 Volt.
You want the lower led to be lit at 9.5 volts (this is 0.86 volts at the input).
So the current through the voltage divider, between the upper and lower led, is (1.25 - 0.86) / 9 = 0.043 A.
If you want 0.86 Volt on the lower comparator a resistor of 0.86 / 0.043 = 20 K is needed.
Intern there is a 1 K, so I would expect a value of 19 K extern on pin 4.
Bertus
david1234
Joined Nov 27, 2013
104
sorry - but I still don't understand
so I need to ask again :
I understand that 0.86 is 9.5/11 ,but why you calculate the current like this - (1.25-0.86)/9 ?
what does the 9 stand for? doesn't need to be 10 ? the sum of the resistors ?
ericgibbs
Joined Jan 29, 2010
18,849
hi,
For 10 LED's there are only 9 intervals/gaps/voltage thresholds between them.
EDIT:
There are tolerances in the LM3914 IC, I would advise where possible you make up resistors, using a fixed value and a variable resistor, so that you can trim the voltages for the Rhi and Rlo.
bertus
Joined Apr 5, 2008
22,277
There are 9 resistors between the highest and lowest comparator inputs.
Each resistor is 1 K, so I use 9 K.
As said, use a fixed resistor in series with a potentiometer to set the lower limit to your needs.
I think you can use a 15 K resistor and a 10 K pot for this.
Bertus
david1234
Joined Nov 27, 2013
104
O.K. - I will try it .
now another question (maybe I don't understand the circuit right):
what is the role of the 5.1K resistor? in the R_High (PIN6) ?
how does it control the high voltage that will light the LED?
Thanks ,
bertus
Joined Apr 5, 2008
22,277
The resistor on pin 6 / 7 determines the led current.
Take a look at the datasheet to determine the value.
Bertus
david1234
Joined Nov 27, 2013
104
O.k.
so something doesn't add up in my head
(I'm applying what you said on the autograph.....)
Let say that my signal is changing between 9-12V but after the voltage divider I only get
Vin_max= (12*10)/(100+10) = 1.09V
Vin_min=(9*10)/(100+10)=0.81V
how does it manage with the other voltage you explain to me ?
Thanks ,
bertus
Joined Apr 5, 2008
22,277
When you want the range from 0.81 to 1.09 Volts, you will have a voltage divider current of:
(1.09 - 0.81) Volts / 9 KOhms = 0.03111 mA.
The resistor between the pins 6 (Rhi) and 7 (Vref) will be:
(1.25 - 1.09) Volts / 0.03111 mA = 5.14 KOhm.
The resistor on pin 4 to ground will be:
0.81 Volts / 0.03111 mA = 26.04 KOhm.
As there is already a resistor of 1 KOhm inside the LM3914, you will need a resistor of 26.04 - 1 = 25.04 KOhm.
I would take a 3.9 KOhm with a 2.2 KOhm potmeter on the top and
a 22 KOhm with a 10 KOhm potmeter on the bottom.
That way you can compensate for component tolerances.
Bertus
david1234
Joined Nov 27, 2013
104
O.K
I think I got it -
I will build and "play" with this and if I have more question I will ask
Thanks you for the help and the explaining
david1234
Joined Nov 27, 2013
104
well It's working
I have change it to 20K
now I want to know is it possible to change the steps of voltage?
now every 0.4V there is a change
can I make it 0.5? or even 0.7V?
Thanks,
