Understanding Syntax
jfeeney
Joined Jul 14, 2008
14
I have the PICKit 2 Express Debug. I am using MPLab and the compiler is set to MPASM toolsuite (when I look in "Select Language ToolSuite". Kit comes with PIC16F887
Can anyone tell me where I can get a pdf Reference Manual for understanding the proper syntax.
For instance in the HelloWorld example (example 1) the program ends with a GOTO $ ; program will wait here. I have never seen a GOTO $. Most of my programming background is Microsoft visual C# or Microsoft Visual Basic.
And in the second example words such as "decfsz".
Should I search the internet for PIC16F887 syntax?? or PIC16F887 instruction set?? or is there a major grouping that the PIC16F887 fits into such as Mid-range MCU's (I seen that term in another webpage).
Thanks for giving me some direction
jfeeney
Joined Jul 14, 2008
14
I was just returning to say that I had found the first link -- to the Microchip Document DS41291E.
I had printed out pages 233-243 which goes over the 35 instruction set.
I still don't understand "GOTO $" -- how that works
The goto is just an unconditional jump (you probably figured that much out) and the $ means the current location. So essentially the instruction loops on itself or, in other words, halts execution. Rather common in microcontrollers.
