understanding garden solar light circuit
Discussion in 'General Electronics Chat' started by tab a, Jan 15, 2015.
  1. tab a
    Jan 14, 2015
    10
    I'm playing around with some old garden solar lights, and 'think' I understand most of this circuit, but do not understand the purpose of D2. Could someone en'light'en me? :rolleyes:
    Thanks.
  2. wayneh
    Sep 9, 2010
    12,389
    3,245
    It prevents the small current flow from Bat+, thru the bias resistors, and thru D3, when Q1 is OFF.
  3. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,699
    1,298
    And, D2/R3 provide positive feedback to latch the regulator ON once it starts. This prevents the LED light output from being detected by the CDS and shutting off the circuit.
    BTW, your diagram would be much more understandable if all of your ground symbols pointed down, and were a correct ground symbol.
    ak
  4. ian field
    Oct 27, 2012
    4,456
    792
    All the solar garden lights I've seen to date used a single nickel cell, which mandates some form of oscillator/inverter which uses a flyback inductor to generate the 3.4V for a white LED.
    It tends to be the older ones that use an LDR - the cadmium sulphide is toxic and not RoHS compliant, the modern ones sense charging current from the solar panel to shut it down in daylight.
    The discrete component variety are getting rare too - these days its usually a black-blob chip or sometimes a 4 lead chip about the same size as TO92.
  5. wayneh
    Sep 9, 2010
    12,389
    3,245
    +1 I haven't seen one in a long time, a decade at least.
  6. takao21203
    Apr 28, 2012
    3,578
    463
    None of these "solar garden lights" is any good
    The output of the tiny solar cell is so little they would only be effective in Africa
    The small battery gives a few hours when new but that becomes less and less pretty quick
    The light output isnt much useful for anything
    Typically the whole thing after a year shows signs of corrosion
    None of these junk properties warrant to use massive metal components for its construction, which indeed could last centuries
  7. ian field
    Oct 27, 2012
    4,456
    792
    I found the wreckage of one built with discretes, on the footpath behind the flats.
    It was also a rarity in having 2 Ni-Cd cells - which were still in the holder.
    That was before I was brave enough to make my own lithium chargers for the e-cigarette - Ni-Cd are the only other sealed rechargeable that can handle the current draw.
  8. profbuxton
    Member
    Feb 21, 2014
    233
    68
    I totally agree with takao21203, These things are total waste of precious resources for no good purpose.
  9. wayneh
    Sep 9, 2010
    12,389
    3,245
    The same could be said of any of us. :cool:
  10. ian field
    Oct 27, 2012
    4,456
    792
    I-robot.
  11. tab a
    Jan 14, 2015
    10
    Thanks. As usual, makes sense once someone explains it! :)
  12. ian field
    Oct 27, 2012
    4,456
    792
    Actually; in I-robot, the machines decided humans needed 'looking after' - it was Terminator machines decided the human race was surplus to requirements.
  13. wayneh
    Sep 9, 2010
    12,389
    3,245
    Well, I was in a hurry and stated the obvious. But if that is ALL it is doing, then removing it would make little difference, just a small current leak. I suspect it does more than that, something about biasing Q2 when Q1 is conducting, but I couldn't quite figure that out. Take it out and see what happens!
