Understanding Full-Adder Circuit
Discussion in 'Homework Help' started by jegues, Nov 22, 2010.
  1. jegues
    Sep 13, 2010
    735
    43
    I'm just having some difficulty understanding the full-adder and the how the carry-in/out are obtained and what effect it has on the circuit.
    See figure attached.
    The original question was to design the simpliest circuit that could determine how many bits in a three-bit unsigned number are equal to 1.
    With the circuit posted in mind lets consider the scenario where z2=z1=z0=1.
    With this we should obtain Cout = 1 and S = 1, giving us a binary value of 3, thus indicating 3 ones were counted in the input.
    The part I don't understand is how the full adder obtains these results.
    How does z2 + z1 = s = 1, and why is Cout = 1? Also, what is the significance of the carry in? If I change the values of the carry in how does it change the output?
    If anyone could clarify it would be greatly appreciated.
    Thanks again!
      File size:
      55.9 KB
      44
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
  3. renotenz
    Oct 25, 2010
    11
    Well... binary numbers only consist of 1 and 0.
    The Full Adder is using the method of binary addition
    0 + 0 = 0
    0 + 1 = 1
    1 + 0 = 1
    1 + 1 = 10
    So if your input Z1 = Z2 = 1, the addition result will be 1 + 1 = 10
    Since there is a Z0 Carry In which is also 1, the result will be 10 + 1 = 11.
    Then the 11 divided as 1 for S and 1 for Carry Out.
    Another example is if you give 0 for the carry in, the result will be 10 (1 + 1 + 0 = 10), the S will be 0 and Carry Out will be 1.
    If the result is only 1 or 0, then it goes to S, and the value of Carry Out is 0.
    Cheers :)
