Hello All,
I studies Circuit theory almost 2 decades back and hardly applied it in my work. Mostly I tend to work in digital area.
I am getting a lot confused with the concept of voltage & current. If I may explain with an example.
I have 2 series resisters of 2 ohm and 3 ohm connected to a 10 v source. The voltage drop across first resister is 4 V and across second resister is 6 V.
Since the current flowing through 2 ohm and 3 ohm resister is same, how should I interpret what exactly voltage is?. Is it the rate at which current flows through R1 and R2 is different and is related to voltage drop?
Similarly, if I keep increasing the number of resisters in the series then the current comes down. Does that mean that current supply reduces as resistance load on a voltage source increases?
Similarly, if number of series resisters are decreased than current increases. Does that mean that rate at which the current flows across the resister increases as the number of resisters decreases?
Thanks a lot in advance ...
