understanding amp circuit
Discussion in 'Homework Help' started by fran1942, Aug 6, 2011.
  1. fran1942
    Jul 26, 2010
    58
    Hello, I have attached a circuit diagram to amplify an electret mic (suitable for feeding into a Picaxe chip.
    I am trying to understand the function of each of the components.
    Can someone please help me with the following:
    - What is the purpose and method of calculating the 10K and 1M ohm resistors ?
    Also, I understand that the .1 microfarad capacitor is there to block unwanted DC noise. Is .1 a standard value to use or was it calculated somehow ?
    Thanks kindly for any help.
  2. Kermit2
    Feb 5, 2010
    3,852
    968
    The 1 meg resistor could probably be left out and not affect the circuit much. I believe it gives a small amount of negative feedback. Very small really. A small resistor could be added in series with the base to reduce gain, or a pot to control gain level
    The 10K resistor sets current for the amp and develops the voltage at output.
  3. Kermit2
    Feb 5, 2010
    3,852
    968
    I take that all back. The one meg resistor is giving a DC bias to the base. It shouldn't be that large though. As a matter of fact the circuit doesn't seem to be likely to work very well at all. The transistor needs to be biased correctly for starters.
  4. Kermit2
    Feb 5, 2010
    3,852
    968
    edit: content removed as not relevant to the subject
  5. Adjuster
    Dec 26, 2010
    2,147
    300
    With the low base bias resistors shown, plus the effect of negative feedback from the collector, the input impedance will be low, severely loading down the output from the microphone. The original circuit would have had pretty poor bias stability, but the input impedance would have been considerably higher.
    The loading effect won't be obvious if you use a sine voltage source directly, but if you add a few kΩ in series to simulate a real microphone the effect should become clear.
  6. praondevou
    Jul 9, 2011
    2,936
    489
    The original picture shows the output going to a 555, I guess to the trigger input? The purpose seems to have a high impedance transistor input, that will imprint an AC on it's output when noise/sound of a certain intensity is detected. Someone correct me if I'm wrong.
  7. Kermit2
    Feb 5, 2010
    3,852
    968
    edit: removed as not applicable to OP's question
