Question :
If there is voltage drop in a line then why the motor would burn or you have to do the rewinding of the motor.
Thank you mike for the reply.Presumably, you are talking about an AC induction motor. If so, then the current that the motor draws from the line increases dramatically as the input (line) voltage to it decreases. Heating losses in the motor windings are proportional to I squared, so if you run the motor on a line voltage which is 10% below its rating, the current might increase to the point where the motor overheats.
One more thingThank you mike for the reply.
Now voltage is the charge that current carries
So if the voltage drops then current would loose the charge
So to get the required power the motor would draw more current
But then why it overheats then.
I am not able to understand this.
Because the current now has less charge so the motor is only taking the power required for its function right
No current is wasted so that it converts to heat.
It is still a induction motor, just split phase.This one is not the induction motor It is a capacitance motor
It requires the start capacitor and running capacitor
"At the point of switch on, an induction motor is a transformer with a shorted turn secondary, it is important for it to start revolving ASAP.It is still a induction motor, just split phase.
If the start capacitor or centrifugal switch has gone then it should start with a quick flick of the shaft or impeller when you apply power.
If the motor is Chinese origin, change the capacitors, as long as the winding's are still OK.
Max.
As you said that if the motor is not turning then there is no magnetic field in the motor to limit the currentThe magnetic fields in a motor at full speed limit the amount of current it requires to operate. If the motor is not turning, like it is when you first turn it on, the only thing which limits current is resistance of the wire.
You should be able to 'smell' if the motor windings have overheated and burned. Absent the strong burning smell, try replacing the capacitors.
In a nutshell!"At the point of switch on, an induction motor is a transformer with a shorted turn secondary, it is important for it to start revolving ASAP.
Can you explain this is more detail ?
How the Slip frequency would decrease : Initially when no load is connected then the slip frequency would be the minimum right. and as an when we connect the load the slip frequency would increase.In a nutshell!
The stator represents the primary winding, the secondary is the rotor which is iron with embedded coils in the form or copper or aluminum bars connected together essentially forming shorted turns.
These bars or turns are used to create (by induction) the required magnetic field in the rotor, the rotor field immediately tries to 'follow' the revolving stator field, the induced frequency in the rotor gradually comes close to the stator frequency, this is called the slip, as the slip frequency decreases, so does the stator current.
If a load is placed on the motor, this causes a increase in slip frequency and so the current increases.
The rotor can never catch up completely with the revolving field, it gets as close as around 5-6 cyles.
A motor that is designed to allow the rotor to catch up with the revolving field is a Synchronous motor.
Max.
If there is a voltage drop in a line then there will high current flow thru stator winding right.You need to troubleshoot the motor.
Remove it from the load by taking off the belt, or unbolt it and disengage it from the gears if it drives a gear box. Turn the shaft by hand a verify that you do not have any rotor bearing problems.
If the motor has a connection cover, remove the cover and inspect the wiring for overheating and verify the screw terminals are tight.
If that all checks out and nothing "smells" burned , proceed with an ohm meter and check for low ohm readings on your stator winding. If it is not "open" then replace the capacitors and hope that is it.
If the centrifugal switch is bad then you will need expert help. Most motors can be repaired if the switch is bad, but it is not a DIY project for the average person.
Q : First If there is less magnetic field generated by the rotor then less current is induced in the stator then why the stator is trying to pull more current from the supply. because here the stator also has low magnetic field because of low current then the slip frequency is also less right. In other words why does the stator wants to bring the rotor back to speed. it would simply stop or the rotor of the motor would rotate very slowly (not generating enough head for the water to reach heights in submersible pump). or is there any microprocessor or microcontroller which is trying to give the rates speed of the motor all the time. Because if the system is only electrical it cannot sense at what speed the motor needs to run.When voltage goes lower, the motor slows down. This means less magnetic field is opposing the current flow into the stator so the stator draws more current and attempts to bring the rotor back up to speed. The increased current at low voltage levels burns out the stator.
It is more complicated than that, but it gives the general idea of why low voltage is bad for a motor designed for a higher voltage.
Q :Torque in the motor is directly related to current, Torque is directly proportional to the square of the supply voltage.
When the supply voltage V decreases, then the torque T also decreases. But there is a load connected to the motor and it requires a constant torque all the time. Thus in order to maintain a constant torque during reduced supply voltage, as a compensation, the speed of the motor decreases.
The torque equation, “T α s * V^2”, as the supply voltage is reduced, the slip increases to maintain a constant torque. As the slip increases the speed of the motor reduces.
T = Torque
s = Slip
V = Voltage.
A point is reached where the relative torque is not able to sustain the fixed load.
Max.
Sir your content is blocked I can't see itYou don't seem to understand the electrical principles so it might help to review.
by Jake Hertz
by Jerry Twomey
by Aaron Carman
by Duane Benson
