Underloaded Transformer
Discussion in 'Homework Help' started by sh312, Dec 10, 2014.
  1. sh312
    Dec 6, 2014
    9
    What are the implications if a transformer is underloaded for example
    A transformer rated 300kVA but the load it takes is only 220kVA
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    There are none. A load takes what it takes and the rating is the maximum load that can be supported without consequences.
    alfacliff likes this.
  3. crutschow
    Mar 14, 2008
    13,509
    3,385
    The only consequence is that the transformer output voltage will be a little higher due to less current through the internal primary and secondary winding resistances.
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Does a little higher mean negligible in this instance. For example if I have 10:1 transformer rated for 5 Amps and I place 120VAC on the primary and draw 1 Amp from the secondary how much does the voltage increase?
