undefined identifier "GODONE"
Discussion in 'Embedded Systems and Microcontrollers' started by HITECHBOB, Feb 13, 2011.
  1. HITECHBOB
    Jan 23, 2011
    I'm using the 16F690 and the pickit2 MPLAB IDE with HI-TECH C Lite 9.81 Compilier. When building the following code I get undefined identifier "GODONE"
    Can anyone help me with this.
    /* This is a simple demo project written for use with
    * the HI-TECH Software PICC compiler. It may be compiled
    * and run on the Microchip PICDEM 2 PLUS DEMO BOARD.
    * Features demonstrated include driving the LCD display and
    * the A2D converter.
    Additional files required for this demo are included in the
    PIC\SAMPLES directories:
    DELAY\delay.c
    DELAY\delay.h
    lcd.c
    lcd.h
    #include <pic.h>
    #include <stdio.h>
    #include "lcd.h"
    /* this is the maximum value of an A2D conversion. */
    #define MAXVOLTAGE 5
    #define SENSITIVITYMASK 0xFC // Reduce precision of A2D result
    void init(void){
    lcd_init(FOURBIT_MODE);
    ADON=1; /* enable A2D converter */
    ADIE=0; /* not interrupt driven */
    ADCON1=0x0E;
    ADCON0=1;
    TRISB=0x00; // Set PORTB in output mode
    T1CON=0x31; // turn on timer 1
    TMR1IE=1; // timer 1 is interrupt enabled
    PEIE=1; // enable peripheral interrupts
    GIE=1; // turn on interrupts
    void interrupt isr(void){
    if(TMR1IE && TMR1IF){
    PORTB++;
    TMR1IF=0;
    void main(void){
    unsigned char last_value;
    unsigned char volts;
    unsigned char decivolts;
    unsigned char outString[20];
    init();
    lcd_puts("Adust the");
    lcd_home2(); // select line 2
    lcd_puts("potentiometer");
    while(1){
    GODONE=1;
    while(GODONE)continue;
    ADIF=0;
    // Mask off the lower two bits as this level of precision
    // is wasted as we're only showing 0.1 volt increments.
    // This reduces unneccesary updates to the LCD.
    if((ADRESH&SENSITIVITYMASK)!=(last_value&SENSITIVITYMASK))
    volts=0;
    for(decivolts=(ADRESH*10*MAXVOLTAGE/255);decivolts>=10;decivolts-=10)
    volts++;
    lcd_clear();
    sprintf(outString,"A2D = %d.%d volts",volts,decivolts);
    lcd_puts(outString);
    last_value=ADRESH;
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Then working with HI-Tech C for mid-range pics always include the htc.h file. Have you read the quickstart.pdf file in the ....\HI-TECH Software\PICC\9.81\docs\ folder. If you use MPLAB always create a project like shown in this document. And is the datasheet for 16f690 in reach. As this is an important document then programming. What is the source of your program. Is the original program for a 16f690? Microchip have a lot of MCUs and the code for one chip. Is not always directly portable to other MCUs. Oh and last how do you take care of your configuration bits.
    Ps the correct header file for your chip pic16f690.h You will find the configuration bits setting at the start of this file
  3. stahta01
    Member
    Jun 9, 2011
    133
    21
    Defining _LEGACY_HEADERS before including the htc.h file results in the old names working. Version 9.81 of HiTech C renamed a bunch of names.
    I posted in this thread because it was the first result search Google using "GODONE" and "9.81".
    Tim S.
  4. be80be
    Jul 5, 2008
    432
    57
    The reason it not working it it's GO_DONE not GODONE
    Change it to GO_DONE and see what happens
