Unconventional Crystal Radio Circuit
Discussion in 'Wireless & RF Design' started by vu2nan, Mar 31, 2015.
  1. vu2nan
    Sep 11, 2014
    43
    10
  2. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    Why Unconventional?
    When we were kids we built them all the time, tricky playing with the Cats Whisker lump of Galena crystal!!
    Max.
  3. alfacliff
    Dec 13, 2013
    2,449
    428
    its just using the bse to collecter junction as a diode. the capacitor is just for smoothing the rectified rf, not for tuninng. with a 200 kw braodcast station nearby, almost anything will work for a "crystal radio", the trick is to make a dedesign that will let you hear farther stations, and for that, you need higher impedance headphones, for less load on the detector, a real paralell tuned tank with variable cap for tuning, and better coupling to antenna and detector for impedance matching.
  4. DickCappels
    Aug 21, 2008
    2,773
    669
    How do you think the Low Z headphones might affect tuning?
    simo_x likes this.
  5. alfacliff
    Dec 13, 2013
    2,449
    428
    there is no tuning, the coil is just an rf choke to develop rf across. the transistor acting as a diode keeps the capacitor from resonating the coil.
    simo_x and BR-549 like this.
  6. DickCappels
    Aug 21, 2008
    2,773
    669
    Thank you for the explanation and new information.
  7. t_n_k
    Mar 6, 2009
    5,448
    783
    The problem with this explanation of the (undoubted) observation is that it doesn't tally with the 'expected' properties of a small signal diode or a diode substitute. One would expect to see only the diode junction capacitance linking the coil and the variable capacitor. The diode junction capacitance is presumably an order of magnitude or more less than the variable capacitor.
  8. MrAl
    Distinguished Member
    Jun 17, 2014
    2,556
    515
    I dont think it looks that unusual either. Low impedance headphones will probably take too much power to run so that might not be a good idea, but you try it and see.
    More unconventional is a crystal radio set made with a home made diode. There are everyday materials that can be used to make diodes that work pretty well for these very low level signals, and that's because there is hardly any current flow.
  9. alfacliff
    Dec 13, 2013
    2,449
    428
    the diode only passes half wave rectified rf, the "tuning capacitor isnt really connected to the coil when the diode is on the other half, so resonance isnt achieved. also, using a low impedance headphone might seem to work on a local 500kw station, but it prresents a high load on the inpur circuit, which by not tapping down on the coil for either antenna or detector, will not let the even if connected correctoly capacitor and coil combination work well. a paralell tuned lc tank has a very high impedance at resonance, and loading it with a low imedance load spoild the "Q" or quality factor of the tank, making the thing have low output and broad tuning.
  10. DickCappels
    Aug 21, 2008
    2,773
    669
  11. Ramussons
    May 3, 2013
    562
    92
    Detector Diodes like the OA 85 or 1N34 will perform better than a Transistor Junction diode.
  12. DickCappels
    Aug 21, 2008
    2,773
    669
  13. ScottWang
    Aug 23, 2012
    4,932
    777
    Using a Germanium diode and crystal earphone, the receiving signal may not enough to drive a low z phone.
  14. alfacliff
    Dec 13, 2013
    2,449
    428
    trhe "crystal set socioty" has a lot of info on crystal sets and lots of different designs.
